wire rope end fitting
hi,
i have to choose wire rope end for 3/16" stailess.
the options are :
1)socket fitting (positive grip) by www.esmet.com
2)creating a loop using wire clips (by crosby clips for example)
does anybody knows what method is more reliable?
the options are :
RE: wire rope end fitting
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
the purpose is to balance weights (at each end).
the balanced item is arm that slides along mast.
thanks,
Lasker
thanks,
Lasker
If I wanted it really reliable I would put a sleeve on it and crimp it in a press. They do that for chokers on wire rope.
My initial reaction would be to stop at Home Depot and get something I could put on with a screwdriver. (Actually I did this a couple weeks ago and I had to use a nut driver but same idea.)
Tom
You can also make a Flemish loop at the end of the wire rope and get a 100% efficiency.
