Cantilevered beam design process
I am an E.I. with a design process question.  I'm sizing two paired 14' cantilevered C Channel's.  They are to be used in place of a single I beam on either side of the column.  I'm considering them independently.  Both are laterally braced (flooring), with 20'spacing(Lu)before the cantilever.  The loads are not excessive (650 lbf/ft) but the Lu seems to be my controlling feature.
Without software, what would be the best design method?  Can I use Allowable Uniform Load Tables with a cantilevered beam?
auxblade
Luke Leising
M.Architecture
B.S.Civil Engineering
