Concrete Cap/thin layer to fix flow problems
There exists a 3 ft wide concrete rim around one of our stand pipes. However, this concrete isn't graded very well and there are plenty of ponds due to the concrete sloping TOWARD the stand pipe. In some spots the concrete is broken up with loose exposed stone due to the standing water.
I've heard of a technique where you can pour a thin 2" layer over the existing concrete. This would take care of the ugly concrete/grading problems. The boss doesn't want to use asphalt.
Anyone familiar with this? How is this new concrete layer bonded to the existing? Pins/rebar at all?
RE: Concrete Cap/thin layer to fix flow problems
Good luck and let us know...
BobPE
