Potentiometer Testing
I have a 2W, 500 ohm potentiometer that has erratic resistance readings. Does anyone have a good web link for testing pots? I was thinking about setting up a test rig to put voltage across the pot and monitor the voltage drop across the pot (or across an in-series shunt) as the pot is cycled.
RE: Potentiometer Testing
If you push on the pot as you turn it and dont get erratic readings then the wiper is loose.
If you have many pots to test one of many viable test setups would be a 3 resistor voltage divider using the pot as the center resistor, a 2W pot can pass a fair amount of current but 5ma should be adequate for a test. You will then need to monitor the voltage at the wiper with an analog meter (or a digital meter with an analog bar graph) and slowly rotate the pot from end to end, and apply a slight up/down force on the shaft if the pot is good you should see only smooth voltage changes on the meter.
