Chamber air temp using COSMOSWorks
Good afternoon,
I have a sealed metal chamber with a heat source on one wall. Is there a way to determine the air temperature/gradient inside the chamber?
SW 2003 SP 0.0
CW 2003 SP 0.0
SW 2003 SP 0.0
CW 2003 SP 0.0
RE: Chamber air temp using COSMOSWorks
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
What you need to do is do model the inside air of the chamber. define your boundary conditions, contact, and set your film coefficients for each face. define the material properties for the inside as air. For this of course you would have to have an assembly by the way. when you are finished meshing and running the analysis you can create plots under your thermal results where you can create a section plot to view the temp gradient,
hope that helps
Jon
jgbena@yahoo.com
