I have a sling over an angle iron,
I have a sling over an angle iron, L2"x2"x3/16", and I'm calculating the hoist capacity. I was just wondering if I should use 0.60Fy as the allowable bending stress, or if I should use a smaller value. I couldn't find anything in AISC-ASD vol. 9 about bending stresses in angles. I'm assuming that 0.60Fy will be fine because the angle is only 70" long and I can't see how an equal leg angle would laterally buckle.
RE: I have a sling over an angle iron,
