online review available
For anyone interested in the new release information for Solid Edge v7, Cadalyst Magazine has a review published in the September 99 issue, as well it can be printed out from there website at www.cadonline.com
I recently made the jump from ver 5 to ver 7, and it's most worthwhile, especially since I was in the middle of a big project at the time. Suddenly some of the workarounds I was using with ver 5 were no longer needed!
Best Regards
Paul Rivet
Best Regards
Paul Rivet
RE: online review available
Greetings from Ottawa!
Yes V7 does include the sheet metal environment, as well as some improved functionality across the board with the part/assembly and draft modules. You can find exact updates at the www.solid-edge.com website.
Best Regards,
Paul Rivet
Mechanical Designer
Canada Post Engineering Services Divison
Ottawa Ontario
Thanks for your reply Paul.
We have been using SE for 2 years now. I did not think it was a productive application until release 5. However since Unigraphics took it over from Intergraph, I think it has improved significantly.
Ted Tracewicz
Project Engineer
ATS Spartec
