I am trying to source some pressure
I am trying to source some pressure sensitive paper that I can sandwich between two mating flat component surfaces & identify any high spots. Any high spots will show themselves as black markings on the white paper, the denser the marking the greater the high spot. Any ideas ?
RE: I am trying to source some pressure
As well as high spots I am also trying to determine the distribution of the clamping force between the two components - this is where the pressure sensitive paper comes into play as it reveals more than 'blue'.
Thanks for comment anyway.
Cory
Machine Design magazine carries monthly advertisements for Fuji(the camera film company)pressure sensitive paper , which gives different colors depending on the actual pressure. Its exactly what you need.
