Design Mesh Size
Design Mesh Size
Hi all,
For waste water stream discharge from incinerator to open sea, i need to design a strainer to filter out the particles in waste water stream that comes from castable dropoff and also salt content in incinerator.
pls advise how should i determine the mesh size required and what's the typical size for waste water streams.
thks.
raingal79
thks.
raingal79
RE: Design Mesh Size
With this data you should then be able to properly size and spec. the strainer and or fliter for the application.
Hope this helps.
saxon
regarding this subject i also have some query. this is about basket or bucket strainer with wire mesh.
if we go for higher mesh size (smaller screen opening), it is good for trapping all those particles. but, most mesh have very low allowable pressure drop. i'd seen few with only 30~60 mbar. this is too low and they are easily damaged if higher or sudden incoming pressure is introduced.
how to deal with this issue? go with two strainers (standby) or select mesh with higher allowable pressure drop?
appreciate some advice.
thanks
