Stepper Motor Torque
The application for a stepper motor includes the expected torque output of approximately 142 in-ozs. What we have measure is approximately 1/2 of expected torque output at the output shaft. Expected torque output of the gearbox (100:1 planitary gearbox, 85% efficient) should be (142 x 100)/16) x .85 = 754.4 in/lbs of torque. Motor torque output is in accordance with the manufacturers torque/speed curves.
We have tested the system for harmful electrical noise and isolated all possibilities.
Are there any other considerations that should be included such as resonance, gear box losses, etc.
RE: Stepper Motor Torque
you say "Motor torque output is in accordance with the manufacturers torque/speed curves."
How you came to this conclusion?
Also, a gearbox efficiency is usually rated in some range of input power.
Are you in this range?
