API 610 application?
A) What exactly governs whether API 610 pumps are required?
B) Are there "crossover" products in the ANSI pump world that could be used with high suction pressure of 150 psig at 383 F, and a boost of 90 tdh is required?
C) If so, when should the ANSI crossover products not be used?
RE: API 610 application?
b) i am not aware of any, but that does not mean there are. it would depend upon pump rating and other factors. check with a good technical rep at pump mfg's.
c) when application & process parameters do not meet or exceed ansi conditions/standards.
-pmover
