Remote Procedure Call
Is it possible to make a remote procedure call from VB inside  MS Excel to another computer on the same network.  I want the remote computer to make a copy of a file on its own hard drive and I want to initiate the action from a VBA macro on my computer.
I can make copies with a local copy command, but I believe that moves the file across the network twice.
Any hints and help with the syntax are appreciated.
RE: Remote Procedure Call
A process could periodically run on remote computer.
The process could shell any command it was told to do.
Schedule could initiate the process at any interval.
