Pressure Fluctuations in Manholes
I am evaluating an existing short storm sewer system (8 structures) on a steep overland grade that has a re-occurring problem of the manhole lids being removed during storm events. To eliminate deep excavation for the pipe, there were numerous manhole step-downs constructed with 4' - 6' in vertical drop. I have analyzed this system in hydroflow, ICPR and XP-SWMM and am getting very similar answers for all three models. Unfortunately, the system is not failing for up to the 25-year storm. The lids have been blown off in much smaller events. I believe I have my hydrology nailed down and accurate.
I have read some articles on pressure fluctuations in manholes that have large vertical drops in the manhole. These fluctuations were large enough to remove the manholes even though the HGL was well below the rim. Has anyone had any dealing with this sort of thing? Any suggestions would be appreciated.
Jim Lee, P.E.
City of Tallahassee
Stormwater Division
RE: Pressure Fluctuations in Manholes
Check a range of inlet loss coefficients, junction loss coefficients, etc. to see if the HGL could conceivably be above the rim due to highly turbulent conditions, or if the pipes are submerged at both ends. Have the pipe inlet conditions been field verified and matched to the coefficients used in the models?
Did the hydraulic models include accurate representation of all the losses, inlets, junctions, bends, etc? If you crank up all the loss coefficients, and the models still don't show a problem, then maybe a TV survey is in order.
Could there be something stuck in one of the pipes?
Another, less-likely, issue could be pipe venting. If both ends of a pipe run are submerged, and the downstream water surface is less than the upstream pipe invert, and normal flow is less than pipefull, then the pipe may be starved for air (in the "midsection"), which could result in pulsing/oscillating flow, which can produce unexpected HGLs. Hard to assess, but easy to fix.....
Your post implies that air pressure fluctuations could be the culprit - I've never heard of this & find it hard to believe so long as the lids have some kind of significant openings, e.g. even if a small hole for a lid puller/hook passes a lot of air! (Hmm, I wonder if they whistle like a tea kettle just before they pop?) If the lids are solid with no openings then maybe a grated lid or supplemental venting would help.
Good luck!
While modeling the system, I did bump up the junction losses until the system failed (K>4.0) but this seemed unreasonably high, especially since I calculated them conservatively at around K=2.5 (I used Christodoulou’s equation for plunging losses).
The pipe venting issue somewhat goes hand in hand with the pressure oscillations issue (article “Pressure Oscillation Induced by Trapped Air in a Trunk-Shaft Sewer System, 2001). I can’t seem to find any way to analyze this numerically.
Well, hopefully the inspection will unearth something interesting.
Jim Lee, P.E.
City of Tallahassee
Stormwater Division
To what degree are the lids vented & what specific type/style of lids are being blown?
And, how much flow and what size pipes are we talking about here?
Even if the lids were replaced to pass more air flow, if the problem is that the pipes are "air-starved" as noted in my previous post, flow could be very unsteady. This could present problems such as extreme vibrations (leading to increased maintenance, etc.) in addition to blowing lids. Flow could be unsteady from siphon conditions forming then disrupting repeatedly; it is doubtful any hydraulic models take this into account, vented pipes are likely assumed in most models.
As noted before, a pipe could require venting if the following conditions are met:
1. Downstream end submerged
2. Upstream end submerged
3. Downstream water surface elevation is less than the pipe crown at the upstream end (entrance).
I recommend checking for this condition using a flow rate similar to what you've observed to cause problems, and somewhat conservative loss coefficients.
A solution could be to install a plate that partially obstructs the top several inches of the pipe at the entrance, and to add a vent pipe that feeds the air pocket that is thereby maintained at the top of the pipe. This is the solution i've seen used effectively on continuous welded HDPE stormwater "tightlines" placed on steep slopes.
BLT
Thanks for all the good suggestions. The lids are normal 2’ Dia (195 lb) lids. The pipes are 36” RCP and an approximate flow is 90 cfs (12.5 fps full flow velocity). Unfortunately, I or the Streets and Drainage folks have not first hand witnessed the actual removal as it is happening. But, we do have eyewitnesses that explain that water is flowing out of the manholes when the lids come off. Also, I placed the lids back on myself after a large rainfall.
I think you are on the right track on air starvation causing oscillation and irregular flow. If it were air pressure only, then you wouldn’t expect to see water flowing out of the manhole. The upstream inlet (headwall) is submerged during the event, and I would expect that at least three of the manholes have a submerged inlet condition.
Jim
Jim Lee, P.E.
City of Tallahassee
Stormwater Division
