Clearing indirect references
It can be a nusiance to copy eqns from cell to cell so this sometimes helps:
'Changes a cell to read the same as the cell it's refering to
Sub ClearIndirectRef()
   With Selection
      FRow = .Row
      RowCt = .Rows.Count
      LRow = FRow + RowCt - 1
      FCol = .Column
      ColCt = .Columns.Count
      LCol = FCol + ColCt - 1
   End With
   If RowCt > 3 Or ColCt > 3 Then
      a = MsgBox("Are you sure?", 1, "More than 3 rows selected")
      If a = vbCancel Then Exit Sub
   End If
   For r = FRow To LRow
      For c = FCol To LCol
         Cells(r, c).Activate
         t1 = Cells(r, c).Formula
         If Len(t1) > 1 Then
            If left(t1, 1) = "=" Then
               a = Mid(t1, 2)
               If Len(a) > 1 Then
                  t2 = Range(a).Formula
                  Cells(r, c).Formula = t2
               End If
            End If
         End If
      Next
   Next
End Sub
