pro/e j-link
pro/e j-link
Can anybody help me with j-link and jdk1.1.8?
When I try to open a session with the following line
session = pfcGlobal.GetProESession();
I get an exception:
Exception caught: java.lang.NullPointerException
at com.ptc.cipjava.CIPRemoteApp.getTransport(CIPRemoteApp.java:22)
at com.ptc.pfc.pfcGlobal.pfcGlobal.GetProESession(pfcGlobal.java:12)
at start.main(start.java:25)
Or has anybody a good tutorial for j-link?
Thank You for Your help
Martin
I get an exception:
Martin
RE: pro/e j-link
RE: pro/e j-link
I get an exception:
My Path and CLASSPATH variables look like as follows:
path:
<JDK Loadpoint>\bin
CLASSPATH:
<JDK Loadpoint>\lib\classes.zip
<J-Link loadpoint>\jars\cipjava.jar
<J-Link loadpoint>\jars\pfc.jar
Compiling is without errors. When I start my applet,
I get always the same errors, if proe is running or not!
Have You any idea?
RE: pro/e j-link
If it is from a browser, you will have to either connect to Pro/E or start Pro/E. Once you have connected, you can get the session. See below. Here timeout is an Integer for how long it will try to connect. I usually use 20.
try
connection=pfcAsyncConnection.AsyncConnection_Connect(null,null,null,timeout);
try{
session = connection.GetSession();
catch(jxthrowable x){
catch (jxthrowable x){
JOptionPane.showMessageDialog(null,"Could not Connected to Pro/E");
As for tutorials, there are some that are in the Pro/E loadpoint - not brilliant but just enough to get you going.
RE: pro/e j-link
