Bendable stainless steel tube
Does anyone know of a UK source for stainless steel tube. It needs to be OK for 40 bar internal pressure with an external temperature of around 600 deg C. I need an OD around 8 - 10 mm, and the tube must be formable to about 200m radius.
Even a suitable material spec will get me on the right path
Thank you all for your help
John W Murphy
Good Luck
johnwm
RE: Bendable stainless steel tube
Look up who handles Swagelock in your area.  They'll be able to give you some names.  In that size, you won't need much wall thickness for pressure retention.
If you ask for a swagelock catalog, they have different grades and sized of SS tubing and what pressures various wall thicknesses can handle.
Thank you and my apologies for overlooking your reply - my email client lost the notification!
Good Luck
johnwm
