Pretty basic Question
Hi Im a new boy to solidworks and have a pretty basic
question. - If I have a piece of RHS - say 25x25x3,
which is the best way of putting a 45degree chamfer.
across the total end face of the member.
Is a plane the same as a surface when it comes to cutting the chamfer?
Thanks in Advance Allan
RE: Pretty basic Question
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
as opposed to chamfer. Also what is the difference (if any)
between surface and plane when it comes to cutting?
Regards Allan
Sketch the miter right on the face of your solid body and use "Insert --> Cut --> Extrude". With extruded cut, you can get away with just sketching a single line across the entire model, but you may want to define the entire cut shape (triangle or trapezoid).
In other words a chamfer - if it's big enough - becomes a miter.
Read my profile & make me an offer... now!
tatejATusfilter.com
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
