electric power steering worm application
I am currently working on a project which involves a DC electric motor providing a vehical steering assist torque. The motor shaft and steering shaft will be perpendicular to each other. My question is... Can I design the correct worm gear solution to work for this application? I think I need a relatively large lead angle in order to keep the steering shaft turning when there is no input from the motor. Another idea I had is a clutch on the steering shaft to let the worm gear freely rotate.
Any ideas will be appreciated.
RE: electric power steering worm application
Thread finish, lubrication and materials have significant influence.
