AISC MANUAL: Clarification of Chapter F
Hi All,
Looking at Chapter F in the AISC Steel Manual (Ninith Edition), the allowable bendig stress may be calculated by equations (F1-6), (F1-7) or (F1-8). Is anyone aware of the rationale behind Equation (F1-8)? It would seem that equation (F1-8) could be used for a rolled mill shape with larger L/rT values and would give much larger allowable stresses than equation (F1-7) would allow.
The commentary seems only to speak about equation (F1-8) in relation to girders and hybrid sections but gives no guidance as to it's applicability with rolled shape mill sections.
Thanks in advance for your thoughts and comments.
JS
JS
RE: AISC MANUAL: Clarification of Chapter F
It's based on testing of lateral torsional buckling. Check "Design of Steel Structures" by Gaylord and Gaylord, Chapter 5.
