coupling face failure
dear sir
I 'VE PROBLEM TO ASK YOU,ABOUT OUR POWERPLANT . ONE MONTH AGO,WE FOUND REVERSE POWER EVENT ON THERMAL POWERPLANT 550 MW.AFTER WE INSPECT MACHINE,WE FOUND GENERATOR DAMAGED CAN'T OPERATED AGAIN.STEAM TURBINE ROTOR (HIP,LP1,LP2 ROTOR) DAMAGED ON ALL COUPLING FACE LIKE ELECTRIC ARC.I'D LIKE TO KNOW COUNTER MEASURE FOR CORRECT COUPLING FACE DAMAGED
RE: coupling face failure
Cyril Guichard
Mechanical Engineer
Sounds like stray current or a static charge.
