Important suspension parameters
I'd like to compile a list of the suspension-related kinematic characteristics that need to be specified when designing a vehicle from scratch. By its nature this is a top down approach.
WHOLE VEHICLE:
Sprung mass
Sprung CG X and Z
Moments of inertia
Maximum steady state lateral acceleration
Ground clearance
roll stiffness (degrees per g of lat acc)
AXLE
position
track
tyre size, hence rolling radius
Jounce travel
rebound travel
track gain in roll
roll center height at design load
roll centre height gain
WHEEL
semitrack gain, ie lateral displacement of contact patch per unit of jounce travel
camber gain
toe gain
KPI
scrub radius
wheel offset
castor
castor gain
castor trail
unsprung mass
static camber
What have I missed? I realise some of these aren't kinematic, and some are interrelated.
WHOLE VEHICLE:
Sprung mass
Sprung CG X and Z
Moments of inertia
Ground clearance
AXLE
position
track
Jounce travel
rebound travel
track gain in roll
WHEEL
camber gain
toe gain
KPI
scrub radius
wheel offset
castor
castor gain
castor trail
unsprung mass
static camber
Cheers
Greg Locock
RE: Important suspension parameters
A couple of others that might fit into the list would be ride frequency, including front to rear percentages and lateral weight transfer percentage distribution front to rear. Another piece of the geometry would be steering axis angle. I am sure there are others
Dave
spindle length
roll steer
hub trail
Stiffnes of the major suspension mounting points, ie on a McPherson Strut, do the strut towers move around
pat
How about transients?
Cheers
Greg Locock
Ramon Mendoza
on to this topic:
Other compliance related parameters that are very important are:
Lateral force steer (deg/g)
Aligning torque steer (Nm/deg)- one of the largest contributors to the front cornering compliance after the tire cornering coeff.
Lateral force Camber compliance (small effect)
Aligning torque Camber compliance (small effect)
The other one I didn't see was TLLTD (tire lateral load tranfer distribution) or "roll couple distribution" which you guys all know is very important for limit understeer)
Ride Camber and Roll Camber
Side View Swing Arm Angle (SVSAA)
Lateral Stiffness (at ground w/o tire)
Fore-Aft Stiffness (at wheel center w/o tire)
Lateral Force Camber Compliance
Tractive Force Steer
Brake Force Steer
