Hiding Axis Tags
Hiding Axis Tags
Hiding Axis Tags
I am currently running Pro/E 2001.  In this version, when I blank the layer containing an axis feature, the axis tag is hidden on a drawing.  On drawings created with older versions of Pro/E, the axis tag text has to be placed in a separate step on a blanked layer in order to hide it on the drawing.
Does anyone know what is causing this difference in behavior, and if there is a way to make an old drawing behave like one created using version 2001?
Andy
RE: Hiding Axis Tags
Andy in the config.pro check display_axis_tags see if that helps
AS
