Constraints to relations and pro/program?
Im creating relations on my features, to gain full control of my model.
Of which i will hopefully transfer into pro/prog.
My problem is that i would like to add constraints to the relations:
eg
solid extrusion circle radius=5
cut in solid circle, radius from center 2.5 dia of cut =1
I want to be able to control the location of the cut on the circle using pro/prog but obviously if a person creates a radius for the cut at over 5 it will fail.....
How do you put a constraint on pro/prog
eg.
radius number
"please enter radius between 1-5"
can be entered into the relations but no actual constraint is working on the model?
Can constraints be put on relations with out using pro/prog?
Please help?
eg
eg.
radius number
Please help?
RE: Constraints to relations and pro/program?
if rad>5
rad=5
endif
if rad<1
rad=1
endif
Petar Nenadic
Viking Johhson
Petar Nenadic
Viking Johnson
