AutoNew Excel Macro Help Requested
Probably a pretty simple request, but I have spent hours crashing excel macros with no luck....
I am trying to create a macro that will format a tab (borders, shading, some text and formulas) when it is created. I have created a 'sample' tab that contains the exact format I would like for the new tabs. I thought I could have the new tab go to the sample tab, copy it all and paste it on the new tab. However, the macro seems to crash because it keeps looking for a specific sheet name (like sheet2 or sheet 3) and as I create new tabs these numbers increment (the sample tab name seems fine as its name stays the same).
Should I be using the AutoNew function? If so, how do I handle the moving between tabs to grab the data and then come back to the new tab, when the name of the new tab will constantly be incrementing.
Any help is MUCH appreciated!!! Thx!
RE: AutoNew Excel Macro Help Requested
Hope this is of some use.
maybe only a drafter
but the best user here!
Another simpler option would be just to copy the entire tab, will this not be good enough?
Cheers,
Joerd
