Coating for ID of 7000 psi Pressure Vessel
I have a need to provide a corrosion resistant coating to the ID of a carbon steel pressure cylinder, with both water and air being the pressurized substance.  Is there an epoxy coating that would be recommended?  Is there any other coating that would suffice?
RE: Coating for ID of 7000 psi Pressure Vessel
BrianOk
Sorry! my post of heresite has too many www's
its www.heresite.com
pennpoint
