Model conversion between Unix & Windows
I'm working with I-DEAS 9 under HP-UX 11.00. Today I just received a model from my friend. He works with I-DEAS 9 too but under Windows 2000.
I can not opent his model. I-DEAS gives me an error message about incompatibility between the model & the hardware.
Is there a tool to solve this problem ?
Thank in advance,
VnPenguin
RE: Model conversion between Unix & Windows
hi,
 ask your friend to export to Archive or Ideas Library Data format. You cannot open direct using mf1/mf2 format. Don't worry, using this conversion the history of the part still remain.
regards
acyc1977
Thank you,
VnPenguin
