BOILER BOOSTER PUMP
BOILER BOOSTER PUMP
We need your advice for the recommended pump casing cover and casing filler material for a Hitachi >Booster pump DV-CH, Feed water temp.: 191,5ºC; Spec garvity of feed water: 0,874; Nº of stages: 1. The existing material is Steel castings and the inspection show severe erosion on the casing and casing cover areas.
RE: BOILER BOOSTER PUMP
