HV-DC links. e.g. French Interconnector
Question:- Can the DC to AC conversion process allow for NGC's system Mvar requirements? Can a Mvar figure be dialed in and the electronic conversion process takes care of the rest?
RE: HV-DC links. e.g. French Interconnector
Can you explain what NGC is?
Keep in mind that HVDC transmission systems consume VARs both at the rectifier and the inverter end. The VARs consumed are a function of the power transfer on the HVDC line.
