Aero-Condenser Pressure Drop
How do I calculate the deltaP in an aero-condenser? The condensation is partial. What is the method?
RE: Aero-Condenser Pressure Drop
Do you need a software or only the ecuation to calculate the pressure drop.
Condenser calculations are different for gasoline than propane.  What type of hydrocarbon are you condensing?.
If you give me datas y would help you.
I need flow inside tube, inlet temperature, fluid name or phisical properties.
thank you
