Hand-like robot
Hand-like robot
Hand-like robot
For designing hand or leg part of the robot,How you doing turning part of
it?The only way is to use a DC Motor.Or is there any other way???
RE: Hand-like robot
Stepper motors or servo motors are fequently used in robotic applications.
xnuke
RE: Hand-like robot
thanks,
but there are some problems.How can I give motion to the robot.I mean Do i have to connect the DC motor and other part with a wire , string or
something?
Or directly I put it near wheel and DC Motor turns the wheel without any
other stuff?
RE: Hand-like robot
You can make the mechanical connections between motors and actuators/manipulators a variety of ways. You should consider doing an Internet search to learn more about the basics of robotics and machine control. It sounds like you're in way over your head.
xnuke
