Access DB path
Access DB path
Access DB path
Hi all!
Does anybody knows how can I retrieve the current access DB path in VB.
I am trying to solve a problem : the Dbase when moved into another folder will retrieve it new location.
Thanks!
Zmei
RE: Access DB path
Look up the CurDir function
Good Luck
johnwm
RE: Access DB path
10X John!
I can not uderstand why yest dhe curdir() was returning the corect path, and today it is returning c:\doc&set\......
WHY???
ZMei
RE: Access DB path
Ahh, CurDir will return the active Windows directory, not the file's path. If you are using Access VBA, you can use CurrentProject.Path to return the path of the active database.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
RE: Access DB path
Thanks a lot!!!!!
Dsi, you saved my life!
ZMEI
