Looking for DIN form factor blank out plate source
I've been looking (so far, unsuccessfully) for DIN-sized blank out plates - 1/16 DIN, in this case - similar in function to the Hoffman Hol-Tite (TM) line of plugs used to blank out circular holes.
There appear to be several sources of adaptor plates (for instance, from 1/4 to 1/16 DIN), but none that simply blank out an empty hole.
These blank-outs should be easy to install, paintable, self-centering, and gasketed.
Anybody know of a company making such a beast?
Bob
RE: Looking for DIN form factor blank out plate source
Suggestion: Visit
http://www.thomasregister.com
and type Connectors: DIN under Product or Service, which will return 95 companies to inquire about DIN form factor blank out plates
