Pour over existing slab
I have a 100,000 square foot facility 30 feet high, that has sloping floors. I need to make it level for racking systems and to be able to run a fork lift that can unrack at a height of 28 feet. One way is to put crushed stone over the existing floor area and pour at least a 6" slab over it to get the proper floor load ratio for this use. The problem is it will cost me $4.00 per square foot or $400,000. Are there any other materials or methods that I can use to make the job less expensive without sacrificing the floor load ratio or the longevety of the floor.
Thank you
Thank you
RE: Pour over existing slab
