Vision inspection system for screws
Hi all, how can i actually snap pictures of screw sides with a CCD camera from the top?
eg.   ______
      \_____/ <-- Camera
        ___
       |___|  <-- Screw
I need to capture both sides of the screws..
Either by using 1 or 2 cameras also can. Is there a method to do so?
Thankz for helps..
RE: Vision inspection system for screws
i mean if there is a system that inspects both sides of the screw for cracks mainly.
Have you discussed this with current system manufacturers?  Two good ones are General Inspection Incorporated and Mectron.  You can obtain more information at:
http://www.geninsp.com
and
http://www.mectron.net
Cory
