Need advise on Capping the ends of Asbestos Cement Pipe?
I have a 8 inch diameter fire water pipe buried in the ground at our plant. The pipe is ACP asbestor cement pipe. We're creating a bypass of the line where will need to cut and end cap the pipe in two locations.
Someone had suggested that the pipe could be capped with a mechanical joint end caps with concrete restraint end blocks. Is this correct procedure? Does anyone a manufacturer I could get more information on mechancial joint end caps for ACP pipe?
THanks
THanks
RE: Need advise on Capping the ends of Asbestos Cement Pipe?
KRS Services
www.krs-services.com
