pickling and passivating
Hi All,
Is it common to pickle and then passivate stainless steel weld joints? Or, it is either pickling or passivate, not both.
or, we need to pickle the material before welding, and then passivate the welds after welding.
I am trying to find out the general weld finish requirements for pharmaceutical/medical industry.
If I indicate the welds need "to be cleaned per ASTM A380", doesn't it mean the need to pickle and passivate?
Lee
Lee
RE: pickling and passivating
If you remove the weld oxide by pickling it does the passivation also.
Some specifications may predate the understanding of the phenomena and not help you understand why these things should be done.
I have more questions, hope you all can help me understand the process a little bit more.
1. Pickling is for cleaning the stainless steel parts (removes oxides on surfaces). Passivation is for enchancing the corrosion resistance of stainless steel(forms chromium based passive layer). Am I right?
2. Is it true that I must clean the stainless steel parts before doing passivation, by either mechanically cleaning (grinding, sanding) OR chemically cleaning (pickling)? In another word, passivation does NOT clean the parts.
>If you remove the weld oxide by pickling it does the >passivation also.
3. What do you mean? If pickling will also passivate the stainless steel at the same time, why sometimes people will do both (pickling and then passivation)? to further improve the corrosion resistance property?
4. Is it common to just "locally" pickle the welds or passivate the welds? How pickling and passivation are done? by spraying, or by submersing the whole part in a tank full of chemicals? The stainless steel frame of the equipment I am working on is as huge as a cnc machine.
Thanks a lot!
Lee
In answer to your last post:
1. Yes.
2. Yes.
3. Pickling is sometimes done with reducing acids such as hydrochloric or sulfuric.*
An oxidizing mixture of nitric + hydrofluoric (at least 5:1) can also be used.
Passivation is normally done in a strongly oxidizing nitric acid solution, which is considered to leave a more protective passive layer, and is required by many specifications. Warm citric acid solutions can also be used for passivation.
*An inhibitor should be used with these to prevent hydrogen pickup.
4. Both processes are done by immersion in tanks of solution when the parts are small enough. Local pickling can be done with acidic pastes. Local passivation can be done with gels.
If the scale is light, or if it is largely removed by wire brushing (SS wire is best) or bead blasting, you can electropolish to get 100% scale removal and passivation. Again, this is done in tanks for small parts, or by ‘brush electropolishing’ for weld seams in large parts. Electropolishing (after mechanical polishing) is a common requirement for pharmaceutical tanks and piping and for medical parts. See Thread338-60778 and Thread330-50008.
By only mechanically removing scale from stainless steel welds, one will end up with significantly poorer than expected resistance to pitting corrosion. This is because the formation of the oxide "pulls" chromium from the underlying metal leaving a layer less than a micron thick which is depleted by a few percentage points in chromium. Acid removes this layer. Secondly, welds of stainless steel usually contain about 0.010% sulfur. This precipitates as CrS aroound inclusions and depletes the matrix there of chromium. This is why pits form at inclusions and why welds have poorer pitting resistance than the base metal. Again, removing the chromium-depleted regions with acid takes away the nucleation sites for pitting.
Welds have critical pitting temperatures about 5 to 10C lower than the base metal, so they need all the help they can get.
Thanks for the responses.
#4 polished surface finish is one of the requirements. After reading all the good comments from you, I realize that I have to do passivation to promote the corrosion resistance. However, I think what I am trying to find out is can mechanically cleaning processes (such as sanding, grinding, polishing) replaces pickling? Or, maybe I should ask is it common to do both before passivation?
If pickling is so aggressive/crude, will it degrade the #4 polished surface finish?
Thanks again.
Lee
Electro-polishing will work as well as acid but your professor is not correct if he's teaching the avoidance of acid is harmless.
1. Austenitic stainless steel are not embrittled by hydrogen picked up by pickling. That is what happens with martensitic steels. It is not a danger in this austenitic alloy system.
2. Grain boundaries, or any other metallurgical feature, which is deficient in corrosion resistance because of its local composition, will be attacked by acid pickl;ing preferentially. You do it initially, under control, by pickling so it won't happen out of control later in service.
3. Abrasion makes a pretty surface and it's harmless for carbon and alloy steel. Don't think that means it's ok for stainless. All that "brushed" stainless you see on appliances has badly compromised corrosion resistance. That is why smart materials specifiers have changed over to rolled-on finishes which look brushed but are really bright annealed.
Depending upon the size of your part, you can have stainless cheaply polished to submicron finish after removing the outer skin. Do you have a drawing?
