Measuring Pressure Drop across device
I want to measure the pressure drop across a device.  The system is 3/16" ID/7/16" OD poly tubing and the fluid is water.  The device penetrates the fluid with a 1mm wide paddle.  The flow rates will vary from 2ft/s to 12 ft/s.  It is desired to build a simple manometer but I don't want the manometer itself (the penetrations to the poly tubing) to create a pressure drop itself.  Any recommendations?
