overcutting corners in an opening
I am a concrete cutting professional and I have been wondering about the strength of cut openings.  Specifically, is there a structural / strength difference between a square cut corner and a overcut corner.  Are there any codes that specify this?
I am asking because of the growing job requirements for square corners (with NO overcut).
isocutter
isoworks@home.com
RE: overcutting corners in an opening
I would think that the overcuts would essentially create a larger "effective" opening than the raw opening you intended to create.  By overcutting beyond the opening corners, the concrete between the overcuts becomes non-structural and you end up with less undesturbed wall/slab than you would have without the overcuts.
In addition, the overcuts may damage reinforcing bars which extend just beyond the opening edge, further reducing the wall/slab strength.
