Graphic Cards
Graphic Cards
I would like to get some information about different Graphic cards which will give reasonably good performance with SE. Can some one give me a comparitive study of ATI and Nvidea cards (Not high end)
RE: Graphic Cards
Also, if you are into it, you can make the GeForce cards softquadro. If you haven't ever heard of it, check out the guru of 3d (www.guru3d.com -- I think). It essentially converts your GeForce card into a high end Quadro card. I've heard by many that it works well, I personally haven't tried it.
--Scott
For some pleasure reading, the Round Table recommends FAQ731-376
RE: Graphic Cards
Don't forget about these links
http://www.solidedge.com/graphics/
http://www.solidedge.com/graphics/v14cardlist.cfm
--Scott
RE: Graphic Cards
Regards, Pekelder
