Revision Number HELP
Does anyone know how to activate this feature. I find it in the properties dialogue box, but think that it would be handy on my layout.
RE: Revision Number HELP
;;;;Beginning of the AutoLISP routine
(defun add-record (/ Xrec Xname)
(setq Xrec '((0 . "XRECORD")
(100 . "AcDbXrecord")
(1 . "DWGPROPS COOKIE")
(9 . "")
(setq Xname (entmakex Xrec))
(dictadd (namedobjdict) "DWGPROPS" Xname)
(prompt "\nType in UPDREV to start this routine")
(defun c:updRev (/ xlist rev)
(setq Rev (getstring "\nEnter drawing Revision Number: "))
(setq xlist (dictsearch (namedobjdict) "DWGPROPS"))
(if Xlist
(progn
(dictremove (namedobjdict) "DWGPROPS")
(dictadd (namedobjdict) "DWGPROPS" (entmakex (subst (cons 9 Rev)
(assoc 9 xlist) xlist)))
(progn
(add-record)
(dictadd (namedobjdict) "DWGPROPS" (entmakex (subst (cons 9 Rev)(assoc
9 xlist) xlist)))
;(entmod (subst (cons 9 Rev) (assoc 9 xlist) xlist))
(princ)
;;;;End of the AutoLISP routine
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
Now can I get that to show up on my drawings by using rtext.
Is this a variable that can be pulled up?
