Deriving a TF from Simulink block diagram
Dear All,
I have a huge Simulink block diagram with many parameters, with 1 input and 1 output that I have determined (SISO system). It is necessary for me to obtain a transfer function of that block diagram for a specific input and output.
Furthermore, to be able to easily manipulate and
discuss about different results I want Matlab to derive that transfer function in a parametric form. Briefly, the "values" of the "variables or constants" existing in the block diagram will be "parametric", but not "numeric". Naturally, at the very end, the desired transfer function
will also be parametric. Is that possible?
PS: There exist functions belonging to the Control System Toolbox ("connect", "blkbuild" and "ss2tf") with which one is able to obtain a user-defined transfer function from a Simulink block diagram. However, with these functions it is only possible to work by assigning "real" or "complex" numbers within an "m-file", so that is not the thing I am looking for.
Thank you,
Erdem
Thank you,
Erdem
RE: Deriving a TF from Simulink block diagram
Sorry again.
Erdem
