SPWM Generation
SPWM Generation
SPWM Generation
I want to know in SPWM Control for Inverter whether the Carrier signal frequency varies or the modulating signal  frequency varies or for a given carrier frequency should we vary modulating signal.
thanks
Skandesh
RE: SPWM Generation
Digital servo amplifiers manufacturers claim that "Space-vector modulation delivers higher motor speed and lower motor power dissipation than conventional sine-PWM modulation"
http://www.digicanmc.com/copley/AccelNet_CAN_Module.pdf
and this is absolutely true.
It is about dynamic range of motor fundamental voltage non-distorted by saturation.
For conventional analog 3-phase sinusoidal PWM suggested by Siemens engineers in 1964 (triangular wave scanning of 3 sinusoidal voltage commands) and 3-phase Y-connected motor maximum non-distorted phase-to-phase (line) voltage is about 15% less than DC bus voltage. This is also the case of 3-phase linear (not PWM) servo amplifier.
There seems to be no physical reason preventing maximum non-distorted fundamental line voltage from reaching DC bus one and this is realized by space-vector modulation.
It is claimed that there is no necessity in digital current loop to gain those 15% of DC bus voltage back and that this could be done by simple analog means that will also work for linear amplifier
http://www.drbrushless.com/articles/3phase/
RE: SPWM Generation
Another digital servo amplifiers manufacturer about additional 15% of voltage / speed from SPWM :
http://www.processingtalk.com/news/bal/bal101.html
BTW, it is about pure sinusoidal modulation - for extra speed overmodulation strategy also counts.
