ABS on cobblestone
ABS on cobblestone
ABS on cobblestone
I try to find the truth of ABS. Can you offer me a site where can we find test results about braking process with ABS and without ABS in different conditions (temperature, road quality etc.)?
Can anybody tell me what is the situation on cobblestone? Is it true that the ABS is worse on cobblestone than a car without ABS?
Best regards,
Irwin
RE: ABS on cobblestone
I don't know about cobblestones in particular, but there are many road surfaces where ABS is worse than non-ABS.
It doesn't matter really, in the vast majority of cases ABS is safer, so on balance it is a good thing.
If you are interested in it why not do the tests yourself, and publish the results?
Cheers
Greg Locock
