gas pilot light. (Propane )
I am passing propane gas through a fibre blanket. The gas is burning under this blanket where I have a pilot light igniting the gas.
Very soon the pilot light goes out as the oxygen is depleted. I need a pilot light system where I need to draw air away from the surface into the furnace area.
Is there a assembly available in Australia. If any suggestions on a design?
Regards Kevin
Regards Kevin
