experience with A/B 1747KE to UsRobotics 56k modem
I am interfacing a 1747KE card to a US Robotics external 56k fax modem. Does any one have experience with such a remote communications link. If so, could you provide me with a little insight? The com cable between the ke card and modem is wired for hardware hand shaking. After speaking to AB tech support, they suggest I wire the com cable for non hand shaking. I also opted for the back plane configuration method of configuring the ke card. Using my PC, I was able to connect to the modem. However I could not get past the modem. It just occured to me to check my computer's com 3 port to verify that the com port settings in RSLinx Pro match that of the computer's com 3. I remember now that I did'nt verify that today. I'll give it a try tomorrow. One more thing I need to inform you of is the fact that the ke card when powered lit the proper LEDS. The ACT, AND DH485 LEDS lit steadily. After attempting to communicate to the modem, the DF1 LED blinked as it should.
Any help will be most appreciated.
best regards, PLCSAVVY
RE: experience with A/B 1747KE to UsRobotics 56k modem
