rodend with roller bearings
Hi All,
Do anyone know where to find/get rodend with roller/ball bearings of bore size of at least one inch in diameter. I need them for high speed applications. The only thing I can find is hanger bearing from SealMaster (SEHB-20), but it uses pipe thread.
Most of the rodends are with plain spherical bearings, they are only good for low speed, high load application.
Lee
RE: rodend with roller bearings
DURBAL in Germany or ELGES both have rod end units with ball and roller bearing heads. Usually used where you need full rotation atthe top end, rather than oscillation.
Try www.durbal.de or your local INA agent for ELGES stuff.
Lester Milton
Telford, Shropshire, UK
Thanks for the response. Durbal makes roller bearing rodend up to 1" in bore size. It is very strange that only one company makes it.
Lee
