Exporting STL
Exporting STL
Is there a way to lower the deviation for exporting a
stl file? the lowest setting I can get is .0034.
I would like to use .0001
Any input would be greatly appreciated.
Frank
Frank
RE: Exporting STL
By the way, are you sure you want .0001mm as your deviation or are you thinking in terms of inches? (My settings are in mm by default.)
Jeff Mowry
DesignHaus Industrial Design
http://www.designhaus-i-d.com
RE: Exporting STL
Our current software(Cocreate's SolidDesigner)
we can change the setings to any value we would
like as long as the PC can handle it .0001in is about max.
With SW you are limited, the lowest setting is not fine
enough to create a smoother part.
Yes I am using inches.
Frank
RE: Exporting STL
Jeff Mowry
RE: Exporting STL
I gave that a try and the MM lowest setting is
the same as the lowest inch setting.
Have you tried to do a custom setting and
set it lower that the Fine setting? It will
not let me go any lower that than fine in MM or In
Thanks a lot for the tips!!!!!
Frank
