Zinc Oxide Sinters
Zinc Oxide Sinters
Hello All,
I need information on zinc oxide sintering for transforming it into hollow spheres ?How it is done ?Information on sintering furnace? Cost involed in the process? Crucial paramters? List of vendors who do sintering
Waiting for your reply
Thanks & Regards
sj
Thanks & Regards
sj
RE: Zinc Oxide Sinters
Thanks for replying
I dont know the exact volume but around 1 ton .The thickness of the sphere wall will be around 1/2 - 1.0mm.
sj
Manfred.Nebelung@ikts.fhg.de
On your own, I could only suggest sputtering or evaporating over a polymerc sphere which you later burn out.
Thanks for yr info
I e-mailed the person but I got a reply message which is in different language so couldnt understand it
Anyways do you(or any particular website) have any idea how sintering is done(cost/ton,process parameters etc) because i have very less knowledge in this subject
The other info i have is density is 1.2-1.4g/cc (Apprx),
Di/Da -2 mm
Waiting for yr reply
sj
