Inventor 7 Welds
Inventor 7 Welds
Inventor 7 Welds
Is there a way to add a physical weld to two faces that DO NOT interact but are close.
Thanks in advance.
RE: Inventor 7 Welds
Not at this time.  There are improvements being made to the welding environment.  You can use a cosmetic weld in the mean time to at least hold the weld information.  Or use a catepillar in the IDW...
Sean Dotson, PE
Inventor Tutorials & More
www.sdotson.com
