More than 2 saddle supports, Zick?
Does anyone know of a modification to the Zick analysis that would enable 3 saddle supports instead of 2. Are there any other design methods for using 3 supports. I know that 3 supports are usually not desirable but I am tryinig to determine stresses in an existing unit having 3 saddles.
Thanks in advance!
Thanks in advance!
RE: More than 2 saddle supports, Zick?
Send me at e-mail
Leonard@thill.biz
www.thill.biz
athomas236
Narendra K. Roy
Gramya Research Analysis Institute,
PO box 4016, Vadodara 390015, India
Website: www.gramya.com ; www.charismaglobal.com
Be aware, that for the calculation of saddles reaction, you need to consider not only the vessel stiffness but the kind of support "beneath" the saddles (steel structure??) because the problem can be a continuous beam on elastic supports.
